Why Mac configurations fall out of sync — and how to fix them
Practical guidance for small IT teams with limited time and resources about how to consistently maintain, secure and update devices without adding to IT workloads.
End configuration chaos
As businesses grow, their Mac fleets become harder to manage consistently. Settings diverge, updates fall behind and devices become increasingly unique. This increases risk and creates unnecessary work for small IT teams.
Does this setup sound familiar? Well, you're not alone. Inconsistency is a common problem! Read on to discover how small teams can rein in the chaos and set themselves up for fewer problems down the road.
Key points
- Growing businesses can often have inconsistent settings on their Mac fleets, which leads to gaps in security and user experiences.
- Consistent settings save a great deal of IT time, create better end-user experiences, strengthen security and reduce reworks and manual fixes.
- Small IT teams can keep Macs consistent by implementing automation, standard configuration guidelines and ID-based access.
What causes inconsistency as businesses grow?
There are many understandable causes of this type of inconsistent setup, especially as businesses grow from small, fly-by-the-seat-of-your-pants businesses into larger organizations.
When you're pulled in all directions and everything has a deadline of 'yesterday,' it can feel faster to just manually address the problem in front of you rather than taking the time to research and set up helpful tools.
Here's what starts to happen:
- Depending on who handles onboarding in a particular week or day, Mac configurations can be slightly different from each other.
- Without being able to see into each Mac, IT can't see how many settings drift over time.
- Manual updates often lead to inconsistent patch levels.
These seemingly small changes can lead to big headaches down the road for IT.
Why consistency matters
With the right solutions in place to standardize and automate configurations, IT experiences:
- Fewer support tickets
- A stronger security posture
- Predictable behavior across devices
- Easier troubleshooting
- Protection against misconfigurations
- Reduced rework and manual fixes
How small IT teams can keep Mac settings consistent
Standardize new device setup
When IT can be sure that each new device has the most optimized setup, there are fewer surprises and thus fewer fixes. This saves IT time, cuts back on end-user frustration and keeps everyone more secure.
You can accomplish this with:
- Zero-touch provisioning: Use a solution that allows IT to set up devices remotely no matter where tech staff is located or where end users work.
- Integration with Apple Business Manager: Medium-sized businesses leverage volume purchasing through Apple Business Manager with an MDM provider for their device enrollment. This means that from the get-go, they have visibility into all company devices – even when they're mailed directly from Apple to the end user.
- Blueprints and compliance benchmarks: Templatizing setups based on role and department make for fast and uniform provisioning. Save a blueprint or compliance benchmark as part of the setup for new devices and you'll know that everyone has a standard setting, even if that setting is customized by role and department.
Automate updates and patching
One of the most common ways that devices can slide out of compliance or alignment is through patching and updating. When your IT team automates OS updates and patching based on each device's configuration, there is no room for human error. With Apple's relatively new Declarative Device Management (DDM) protocol, devices proactively reach out to the server to report when they need updates or are no longer meeting compliance, and with proper configuration settings, these updates and fixes can deploy without anyone touching the interface.
Use configuration baselines to maintain alignment
Using blueprints and compliance benchmarks, IT can ensure that each device is configured correctly. As roles and devices change, it's important to manage devices and users using Smart Groups: lists of devices and users that update dynamically based on permissions, roles and devices. All these capabilities work in the background with DDM to ensure that each device and each user always have the correct configurations to smooth business processes and save IT time.
Apply identity-based controls to ensure correct access
Ensure access and reduce redundant IT workflows at the same time! Use a solution that integrates seamlessly with an identity provider (such as Okta or Microsoft Entry ID) to allow admin privileges (temporary and fixed), cross-location content and network access and even entry to buildings.
Monitor key settings and automate remediation where possible
Here is where DDM shines. After IT staff have created configuration settings, DDM allows devices to proactively reach out to the server to report when they have fallen out of compliance. Set up correctly, the device and the server can automate any changes or fixes needed to keep the device properly configured.
How unified management plus security solutions support consistency
When management and security tools work together, they catch inconsistencies sooner and can implement remediation faster — often without the need for any staff action. Similarly, automation in setup and in compliance enforcement reduces human error. With DDM, updates and baselines stick because if they deviate at all for whatever reason, your system is set up to be self-correcting for all but unusually complex issues.
Standardization becomes sustainable when you have processes and frameworks set up that automate detection, remediation and configurations as much as possible. When you have figured out how to keep standardization rolling in your organization, it's time to reap the benefits.
How does consistency and syncing help IT teams save time?
- Standardized configurations and repeatable deployments save time and reduce manual rework
- Proactive updates reduce risk caused by inconsistent settings
- Automation supports predictable, scalable IT operations that grow even when IT staff doesn't
- Guided management creates a smoother experience for end users and encourages IT team confidence as the organization grows
Want to get started?
As you can see, maintaining consistent settings for day-to-day business and for endpoint protection can make a world of difference for your growing organization. If you'd like to see how Jamf can help you become that consistent, please contact us.
Even if you decide that Jamf doesn't fit your needs, you can follow specific steps for onboarding new devices or users that will get you off to a consistent start with our Mac Onboarding Checklist.
Download Mac Onboarding Checklist
