Learn How Netflix Scaled IT Asset Management Globally with Automation and Integrations
Netflix streamlined global Mac management by integrating Oomnitza and Jamf, achieving 99.9% data accuracy, reduced toil, and improved security posture.
September 25 2025 by
Sarah Scudder
Managing technology assets across a fast-paced, globally distributed enterprise like Netflix is no small feat — especially when you’re talking about managing Mac to scale. Manual updates, spreadsheet sprawl and siloed systems simply can’t keep up. That’s why Jason Owens, IT Asset Management (ITAM) Program Owner at Netflix, will take the stage with Donna Wilczek, Chief Product Officer at Oomnitza during the Jamf Nation User Conference (JNUC) to share how Netflix transformed its ITAM program into an automation-first, integration-powered engine for accuracy and efficiency.
In this 45-minute fireside chat, Jason will walk attendees through Netflix’s journey from a manual, error-prone environment to a streamlined global operation. By integrating Oomnitza’s ITAM platform with Jamf and other core systems, Netflix eliminated:
  • Manual data entry
  • Reduced operational toil
  • Achieved a 99.9% data accuracy rate
The result?
  • Better lifecycle control
  • Actionable reporting
  • A stronger security posture
Jason will also highlight how automation and integrations have allowed his small, federated team to scale enterprise-wide ITAM processes without adding headcount. From pre-network asset visibility to off-network asset tracking, Netflix now has a complete picture of where assets are — before they’re deployed, while they’re in use and when they’re ready for retirement.
One of the most innovative parts of Netflix’s program is its use of Doc Agent, Oomnitza’s AI-powered documentation feature. Instead of spending months manually creating workflow documentation, Netflix can now automatically generate and share detailed process maps with global teams, saving hundreds of hours and ensuring consistency across the organization.
This session isn’t just theory — it’s packed with practical examples and lessons learned that attendees can take back to their own organizations. Whether you’re looking to:
  • Improve data accuracy
  • Reduce manual work
  • Tighten compliance
  • or Build a future-proof ITAM strategy
You’ll walk away with actionable insights from a Fortune 200 enterprise doing it at scale.
Explore the session and add to your agenda.
