Note: A special thanks goes out to Ferdous Saljooki who discovered the vulnerability and Jaron Bradley who provided additional research support.
What is Gatekeeper?
Gatekeeper is a security feature built into macOS that prevents the user from executing potentially malicious and/or unwanted software. It is designed to ensure that only trusted software launches on a user’s system by verifying notarization and code signing information.
Notarization is a review process in which a developer submits their software to Apple, where it is scanned to ensure it is free of malicious code. Gatekeeper also plays a role in requesting the user’s explicit permission before executing software downloaded from the Internet and when launched for the first time.
This is all due to the fact that applications downloaded for the first time have an extended attribute placed on them titled com.apple.quarantine. After the user has chosen to run the program — regardless of the Gatekeeper prompts — the operating system will no longer prompt the user when launching this specific application in the future.
Initial Indication of Vulnerability
While investigating websites that host a large number of third-party macOS applications, we came across the popular game hosting website itch.io, where many independent game developers host their games. After downloading and opening a handful of games, we noticed that many would not trigger an alert from Gatekeeper. This made us very curious because not only were these applications being downloaded from the Internet but most were completely unsigned. Upon further testing, we noted that we would only receive the expected Gatekeeper prompts if the application was downloaded from a third-party web browser, such as Google Chrome.
We did note that many applications were delivered in the form of a zip file. By default, Safari has a built-in feature that is enabled that will automatically unzip applications held within a zip file after downloading them.
Oftentimes, when an application was automatically unzipped from this website, it did not have the com.apple.quarantine extended attribute applied to it. It did however have the quarantine attribute on all files under the Contents directory.
Oddly enough, if we disabled the Safari auto-extraction feature and manually unzipped the file by double-clicking it, the application would have the extended attribute set as expected.
The process responsible for automatically unzipping downloaded applications is com.apple.Safari.SandboxBroker. Since the bug only seems to exist when an auto-extraction occurs, we suspected a bug in this process.
Pinpointing the Vulnerability
This of course raised the question, “What’s so special about the zip files hosted on this website?” Fortunately, we were able to answer this question thanks to the great documentation that the site provides as to how games are handled. Developers are encouraged to use an open-source Go-Lang command-line tool called Butler. This tool allows them to easily manage the games which are hosted on their account. Butler analyzes an uploaded application and re-zips it before hosting it for download. We surmised the way in which it was re-zipping the application was causing the bypass to accidentally occur, having no reason to believe that the website creators were aware of the bug.
For testing purposes, we built an application and ran it through the Butler command-line tool. After trying a few different combinations, we were indeed able to skip the Gatekeeper prompts when our custom zip file was downloaded via Safari. Upon comparing the zip file created with Butler to a zip file we created using a standard zip command-line utility, we noticed a subtle difference.
What we noticed is that the root of the zip file points to two different locations. On one, it is pointed at the test.app folder. On the other, it is set to the test.app/Contents directory.
Bill of Materials
To better understand the issue at hand, it helps to have some background on the Bill of Materials (BoM). These objects are used in many different places by Apple to keep a running list of file paths when a major file transaction occurs. For example, if an individual sends a directory to another user over AirDrop, a temporary BoM file is created on the sender’s system that holds a record of all the files that were sent in that transaction. BoM items can even be saved to files in binary format (using mkbom). Many power users are familiar with the /System/Library/Receipts directory, which holds a list of BoM files. The name of the BoM file tells you what software was installed or updated. Looking inside the BoM file tells you which files were created by that software. Using the lsbom command-line utility, BoM files can be printed on-screen.
This can further be seen via the ditto executable which is a fantastic macOS utility for making exact copies of files. Ditto can also be used to create archives as well as extract archives. In fact, if we use a different browser to download the same test application used above (that doesn’t automatically unzip applications), we can then use the ditto executable to unarchive the zip file resulting in the same lack of quarantine extended attributes.
The reason behind this is that Safari and Ditto share the same logic calling a low-level function named BOMCopierCopyWithOptions, located within /System/Library/PrivateFrameworks/Bom.framework.
In a debugger, we can see the options that are passed to this function when ditto is used in unarchiving a zip file.
Most notable here is the extractPKZip and copyQuarantine options. Although there is no documentation on BoM files being used with zip files, this function seems to imply there might be some low-level functionality that uses a BoM object to keep track of files extracted from zip files. Presumably, if we can keep our application’s root directory off this list of files, the extended attribute will not be applied to it.
Crafting the Bypass
As mentioned earlier, if the quarantine attribute gets applied to files or folders under the test.app directory, Gatekeeper is not triggered. The application itself is all Gatekeeper looks for.
We determined that the easiest way to confuse the BoM function is by ensuring that the root of the application is not the first local file header of the zip file. For example, we took an unsigned application named test.app and placed it in a zip file using the following command:
ditto -c -k --keepParent path_to_unsigned_application zip_file
We then opened this zip file in a hex editor and removed the entire first Local File Header.
A simplified solution with less chance of breaking the central directory record would be to zip an application using the following command:
zip -r test.zip test.app/Contents
This causes the test.app/Contents directory to be the first local file header and ultimately results in a bypass of Gatekeeper once the zip file is downloaded via Safari.
Detections
Jamf Protect offers a holistic Mac endpoint security solution that provides analytics that detects anytime this vulnerability is potentially being abused. It does this by monitoring the com.apple.Safari.SandboxBroker process and detecting when it automatically unzips an application. It goes on to verify the extended attributes of the extracted app, effectively detecting a missing com.apple.quarantine attribute.
Conclusion
In our testing, we observed this detection working as far back as Safari 14.0.2 on macOS Big Sur. Apple has patched this vulnerability in Safari 15.4.
Mickey Jin (@patch1t) also stumbled upon this bug at the same time Jamf Threat Labs did, however, he discovered that the bug could be abused somewhat differently via a gzip archive.
In the past, we’ve seen malware authors implement novel ways to bypass Gatekeeper, which indicates that they see value in these types of attacks. For this reason, Jamf Threat Labs remains active in finding ways Gatekeeper can be bypassed, in order to further enhance the security protections afforded to Jamf Protect customers.
Jamf Protect's endpoint security is purpose-built for macOS to safeguard your data, users and devices.
Contact Jamf, or your preferred representative today to request a trial and get started protecting your fleet of Apple devices.
Subscribe to the Jamf Blog
