Integrating with Active Directory Certificate Services (AD CS) Using Jamf Pro, Version 10.30.0 or Later
This guide provides a step-by-step workflow to integrate Jamf Pro with Active Directory Certificate Services (AD CS). Integrating with AD CS allows you to add AD CS as a PKI Provider in Jamf Pro to use as the CA for distributing certificates to devices via configuration profiles.
