Integrating with DigiCert Using Jamf Pro, Version 10.16.0 or Later
This guide provides a step-by-step workflow to integrate Jamf Pro with the DigiCert PKI Platform. Integrating with DigiCert allows you to add DigiCert as a PKI provider in Jamf Pro to use as the certificate authority for distributing certificates to devices via configuration profiles. Version 10.16.0 or later.
Latest version:
10.40.0 or Later
Version 10
